Leica User Forum
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Register now
Old 08/06/08, 01:03 PM   #1 (permalink)
Erfahrener Benutzer
mhoersch's Avatar
Frage R Zooms can't be fitted with ROM?
I sent a newly acquired Elmar R 4/80-200 (11280) to Solms to have it fitted with ROM. They wrote back this couldn't be done. Since Erwin Puts in his Leica Pocket Book expressly states that it is possible I called CS in Solms, but they confirmed: it can't be done with any Zoom lens because there isn't room enough in the mount.
I find this hard to believe because the very same lens could also be bought with ROM in the first place (11281).
Has anyone had the same reaction from Solms? Is it really not possible or don't they want to do it for some reason?
__________________
Regards / Gruesse
Manfred
www.manfredhoersch.de
mhoersch is offline   Reply With Quote
Old 08/06/08, 01:46 PM   #2 (permalink)
Moderator
stuny's Avatar
Default Re: R Zooms can't be fitted with ROM?
Manfred -
This is strange. All the recent zooms I've used or owned have the ROM contacts. I too wonder what gives.
__________________
Stuart
www.barbara-and-stu.com
stuny is offline   Reply With Quote
Old 08/06/08, 03:30 PM   #3 (permalink)
Erfahrener Benutzer
masjah's Avatar
Manfred and Stuart
What bad luck! Maybe with a zoom lens there is a greater difference between the ROM and earlier versions than just the fitting of the ROM chip and removal of the earlier than 3rd cams. Certainly in the case of some of the non-constant aperture zooms, information is sent to the camera about the "true" aperture set on the the lens. (You can see it change in the viewfinder as the focal length is changed.) This means that there must be some sort of potentiometer (or similar device) controlled by the zoom ring. So the actual zoom mechanism of the newer ROM versions may have been changed.
__________________
Best wishes.
John
John Howarth
masjah is offline   Reply With Quote
Old 08/06/08, 04:07 PM   #4 (permalink)
Erfahrener Benutzer
jaapv's Avatar
It may well be that there was a modification to the lens mount to accomodate the ROM. That would mean that they would have to change the mount as well on your lens. It is not very important though - I see very little advantage in having the ROM.
__________________
Jaap
WWW.JAAPVPHOTOGRAPHY.EU
Skype: JAAPVPHOTOGRAPHY
jaapv is offline   Reply With Quote
Old 08/06/08, 11:46 PM   #5 (permalink)
Erfahrener Benutzer
mhoersch's Avatar
Thank you all for your responses. Someday I'll find a copy of the lens with ROM and try to find out what the difference is...
__________________
Regards / Gruesse
Manfred
Old 08/07/08, 06:10 AM   #6 (permalink)
Benutzer
That's too bad. I e-mailed Leica customer service as per their website about updating my 70-180 to ROM but never got a response. Do these people ever answer e-mails? Why invite their customers to submit inquiries and then not respond? Good to know ROM is of limited value anyway...I guess.
I sent an e-mail to Zeiss last month about a loose front element on a Hasselblad lens and they responded within hours.
razerx is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
