Leica User Forum
Go Back   Leica User Forum > International User Forum > Customer Forum
090909 Promo
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Register now
Old 20.07.2008, 13:06   #1 (permalink)
Neuer Benutzer
Daumen hoch C-Lux 2 camera can turn on in the case - solution
There is a "flaw" with the C-Lux2 camera and it's Leica made leather case that is very important to be aware of:
It is very easy to activate the camera simply by putting it back in its leather case, as the on/off button is located on the top of the camera in a way that makes it very easy to accidentally activate if the button comes into contact with the side of its carrying case.
This can result in the lens servo-motor breaking down in it's attempt to open the lens with the camera while it is in the case.
To solve this problem, always turn the camera to the playback position before you put it back in its case. If the camera is turned on with the dial in the playback position the lens remains withdrawn into the camera body. To avoid running down the battery, if the camera should turn on while in the case, set the camera to Powersafe 5 min, and it will shut down after five minutes if accidentally turned on while in the case.
Copenhagenmail is offline   Reply With Quote
Old 20.07.2008, 13:33   #2 (permalink)
Moderator
stuny's Avatar
Default Re: C-Lux 2 camera can turn on in the case - solution
MW -
I discovered the flaw you describe by slipping the camera into my pocket, and I found a solution that should work for you without having to set the mode selector to playback. If you want to be ready to shoot quicker after taking the camera out of its case, try inserting it into the case other end first so that the on/off switch is pushed in the off position as it slides into the case.
__________________
Stuart
www.barbara-and-stu.com
stuny is offline   Reply With Quote
Old 20.07.2008, 13:45   #3 (permalink)
Neuer Benutzer
Daumen hoch Re: C-Lux 2 camera can turn on in the case - solution
Quote:
Originally Posted by stuny View Post
MW -
Many thanks for the suggestion.
However, I have - and use - the long neck strap, so this is not possible. It only allows inserting the camera in the vulnerable manner.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
