Leica User Forum Webinar Nov 15 2008
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Register now
LinkBack (1) Thread Tools Display Modes
Old 06/25/08, 01:21 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Erfahrener Benutzer
darkness30's Avatar
Default Aquarium Photography
Hello,
I have a nice aquarium with lots of Rainbowfish in it. I would like to photograph fish but I know it is tricky. If someone has any experience please help. I have R equipment.
Thanks,
Mehmet
darkness30 is offline   Reply With Quote
Old 06/25/08, 01:43 PM   #2 (permalink)
Moderator
stuny's Avatar
Default Re: Aquarium Photography
I've done some of this, but other than remaining very conscious of the backgrounds and angles, I see little difference compared to "dry" semi-close-up photography.
__________________
Stuart
www.barbara-and-stu.com
stuny is offline   Reply With Quote
Old 06/25/08, 10:09 PM   #3 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
Maybe use a rubber lens hood which you can press right up to the glass to avoid reflections, or of course a polariser filter.
You'll need to compensate for the colour balance at the shooting or printing stage.
__________________
Regards,
James
www.earleygallery.com
earleygallery is offline   Reply With Quote
Old 06/25/08, 10:48 PM   #4 (permalink)
pgk
Erfahrener Benutzer
Assuming two things:
You are shooting with an SLR, and that you are trying to take details rather than the whole aquarium.
Firstly, you must always have the lens axis perpendicular to the aquarium glass, any deviation and you'll get some unpleasant and increasing softness depending on the angle.
Secondly, you will almost certainly need to use flash and ensure that this is well off camera and that it does not illuminate light coloured elements outside the tank. You might want to use a large piece of black card, with a hole cut for the lens,in front of the camera. This will minimise reflections - although it is best to have the lens as close to the glass as possible.
I usually have the hood against the glass to help square up and minimise reflections, and have undertaken a great deal of aquarium photography over the last 25 years. Polarisers are of little use though!
pgk is offline   Reply With Quote
Old 06/26/08, 12:35 PM   #5 (permalink)
Erfahrener Benutzer
darkness30's Avatar
Stuart, James, Pgk thank you for your kind and informative replies. I am not going to shoot the whole aquarium, just the fish. I have R9 and 100mm Apo macro lens. I also have 50mm summicron with closeup lens and a circular plarizer and a 60mm macro elmarit. Which lens will be appropriate to use?I have mostly 100 ISO slide and negatives but i will receive some 400 and 800 ISO slides from States. I have a vivitar thyristor flash and i think i can use it at least from its cord length distance. Any other thing that i should pay attention to?
Thanks,
Mehmet
Old 06/26/08, 12:37 PM   #6 (permalink)
Erfahrener Benutzer
darkness30's Avatar
James, where can i find more info on color balance correction for polarizers?
thanks,
Mehmet
Old 06/26/08, 02:33 PM   #7 (permalink)
Erfahrener Benutzer
Quote:
thanks,
Mehmet
Mehmet - you shouldn't have any issues with the filter, I was thinking more in terms of the lighting (assuming that you would be shooting with the aquarium lighting, if you use your flash then its not such a problem).
__________________
Regards,
James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/customer-forum/57004-aquarium-photography.html
Posted By For Type Date
Aquarium Photography - Leica User Forum This thread Refback 06/25/08 02:04 PM
