| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more spcialised sections |
#1 (permalink) |
Erfahrener Benutzer
Yesterday night I wanted to take & post a pic of an old lens of mine (it's in the historical section... Summaron 35...) ; I was uncertain between using my favorite macro set (Tele Elmar 135 head on Visoflex) , or the quickier Summicron Dual Range: I decide for this because the subject was inclined, 3-4 cm of effective "visible depth" and I wanted a decent depth of field... but, afterthat, I was caught by a tech doubt... is it really so ? I never went in depth with the math of DOF... question is: if one achieves the SAME field of view (say, a 36 x 54 rectangle, ratio 1:2 on M8) with a 50 and a 135 lens, of course with diaphragm closed the same, is the effective depth of focus different ? I'd say yes,but, not knowing the math at the base, am not at all sure...
#2 (permalink) |
Erfahrener Benutzer
The (Ilford) Manual of Photography gives this formula for depth of field at near distances:
Total Depth = 2*c*N*(m+1)/m^2where c is circle of confusion, N is the numerical f/stop and m is the magnification ratio. Focal length isn't a factor. |
#3 (permalink) | |
Benutzer
Quote:
with f the focal length. So there is really a difference for all ratios m (Luigi is right), but the difference is very small for c approaching 1. For Luigis case: c=0.33, m=0.5, and N=16 it is 6.403mm versus 6.400mm. |
#4 (permalink) |
Erfahrener Benutzer
As DOF is a function of magnification there is a difference in DOF between an image of the same size taken by different lenses. The magnification of fore- and background is different, even if the subject is the same size on the sensor. However, in macro work, DOF is so narrow that it does not really make a lot of difference.
__________________
Jaap MY GALLERYAt RFF My NEW gallery: http://forum.getdpi.com/gallery/brow...r&imageuser=50 |
#5 (permalink) |
Erfahrener Benutzer
Thanks for the quick answers, straight & clear... but... you say c is the circle of confusion (I remember to have often seen the term "CoC" for it)... is it correct an estimate value of 0,33 mm for M8 ? I know it's a questionable issue, but seem to remember to have seen, somewhere, a magnitude-different value, like 0,023 or 0,027... maybe I'm missing something...
I checked some Net resource... there are lot of... but the values are typically in the range 0,02x mm Last edited by luigi bertolotti : May 5th, 2008 at 09:46 AM. |
#6 (permalink) | |
Erfahrener Benutzer
Quote:
#7 (permalink) | |
Erfahrener Benutzer
Quote:
As ghammer says, the formula I posted is an approximation. It's good enough for everyday "macro" work. |
#8 (permalink) | |
Benutzer
Quote:
#9 (permalink) |
Erfahrener Benutzer
Formally it should be 0.023. However, given the more precise nature of a sensor, resulting in a more pronounced DOF gradient, a circle of 0.02 would be more appropriate.
__________________
#10 (permalink) | |
Erfahrener Benutzer
Quote:
The simpler formula I posted gives 6.4mm DoF for either focal length, so the difference between the two formulas is negligible here. But a 1/30 mm CoC for 35mm equipment dates from the 1920s and 30s . Modern lenses, films and sensors are capable of much better performance and it's often appropriate to work from a much smaller CoC - especially with a "cropped" sensor like the M8's. At 1/50mm CoC and 1:2 magnification and f/16, total DoF is less than 4mm. I'll leave it to someone else to calculate the effect of the lens extension on f/stop on DoF! Last edited by giordano : May 5th, 2008 at 10:21 AM. Reason: extension |
#11 (permalink) | |
Erfahrener Benutzer
Quote:
And this last statement is intriguing... I know that with significan "bellows extension" (or Viso + rings and so...) one has to take into account an "EV factor" (figures exist on bellows specs...) : this means that the "real f/stop" is closer than the nominal... but DOES this affect DOF ? My guess is "no"... but, as you say, stand to be corrected by someone else... ![]() Reasoning "crudely" on the lens wide open : the "EV factor" becomes accountable at significant extensions for not all the light that passes through the lens systems reaches the film/sensor... the effective angle decreases... a certain amount of lightrays are "lost"... so, one can guess that for some "small" f stops closing the real exposure doesn't change... imagine a f 2,5 lens, very extended by bellows... if i close to 2,8 only, maybe the lightrays blocked by the diaphragm are anyway "unuseful" due to the extension... oh well, let's wait for some real math from someone... Last edited by luigi bertolotti : May 5th, 2008 at 11:32 AM. |
#13 (permalink) |
Erfahrener Benutzer
Yes, lens extension will influence DOF. The light loss you mention is caused by the lengthening of the focal length of the lens. The aperture is a mathematical function of the effective diameter of the lens and the focal length, so you are reducing the "real" aperture, effectively influencing DOF. The relation between the influence of the focal length/magnification shift by the extension and the shrinking of the aperture I leave to somebody else...
__________________
#14 (permalink) |
Benutzer
This si all true when one considers an "ideal lens".
The coc may also get defined -enlarged by the resolution of the lens , not byt the resolution of the sensor/ film only. That would be also true for the size of the apreture, the lens when stopped down also looses its performance, therefore apparent depth of field increases. The older , poorer lens might exhibit, or rather make impression having larger depth of field. Jan |
#15 (permalink) | |
Erfahrener Benutzer
Quote:
N/f = 1/D where D is the nominal Diameter of the lens (front lens in std. lens designs) How one has to treat N and f into an "extension environment" ? Does f must be set at the "lenghtened" value due to extension ? Does N has to be still treated as the nominal Fstop set by user ? Or... do the two values result into an INVARIANT ? ("real" f increases with extension, so as "real" N....the ratio...) |
#16 (permalink) |
Erfahrener Benutzer
I will be happy to be corrected if I am wrong,it is becoming a bit abtruse, but numerical f-stop I think means calculated f-stop, as opposed to the one indicated by the f-scale. So it should be actual lens diameter divided by real (=extended) focal length. The f=extended focal length in that formula afaik.
__________________
Jaap MY GALLERYAt RFF My NEW gallery: http://forum.getdpi.com/gallery/brow...r&imageuser=50 Last edited by jaapv : May 5th, 2008 at 03:34 PM. |
#17 (permalink) | |
Erfahrener Benutzer
Quote:
#18 (permalink) | |
Benutzer
Quote:
#19 (permalink) |
Erfahrener Benutzer
The problem is, the focal length of a lens is fixed at the given value only at infinity and lengthens as it gets focussed closer, creating a smaller aperture of course. So in your formula f is the focal length at infinity and N the aperture at infinity?
__________________
