Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags:
Old 04/30/08, 03:08 AM   #1 (permalink)
Neuer Benutzer
Default ernst leitz 90mm lens
This lens has humbled me. I do not understand the focussing mechanism. Is it a fixed focal length and I should just be happy with the image that matches up in the rangefinder or am I missing something? If I push the silver button on the side, I can adjust from 300 feet to infinity. Should I not be able to use the rest of the range from 20 to 150 feet?
Marisa
Marisa is offline   Reply With Quote
Old 04/30/08, 07:30 AM   #2 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
Default Re: ernst leitz 90mm lens
Can you give some more detail on the lens and the camera you're trying to use ? From your post, I suppose is some Leitz lens mounted on a Leica Rangefinder body; usually, the silver button on the side unlocks the movement of the focus helicoid, that in 90 mm lenses usually has a range from 3 feet to infinity : looking into the Viewfinder/rangefinder you must match the double image at the center of the view: when they are coindident, the subject is in focus.
But I don't remember of a 90 mm Leitz lens that has the silver button... they are typical of shorter focals like 50-35... how is the engraving on the front ring of the lens you are speaking of ?
luigi bertolotti is offline   Reply With Quote
Old 04/30/08, 09:54 AM   #3 (permalink)
Erfahrener Benutzer
Lotw's Avatar
Default AW: Re: ernst leitz 90mm lens
Never let yourself humble by a Leica lens!
Lotw is offline   Reply With Quote
Old 04/30/08, 09:50 PM   #4 (permalink)
Erfahrener Benutzer
Marissa - please give us some more information to work with. Specifically, which Leitz lens is this...it should say on the front of the lens. Is it a collapsible lens or a rigid mounted lens?
spydrxx is offline   Reply With Quote
Old 04/30/08, 11:58 PM   #5 (permalink)
Benutzer
I have the Elmar 90mm f/4 lens (chrome, long, not collapsible.)
If you are talking about the silver button on the camera by the side of the lens, do you mean the lens locking mechanism on the M ? That is for locking and unlocking the lens when you want to change it, not focusing it.
If that is not what you mean, but are wondering more on focusing, on my model, with the focus point set on infinity, that is the point which will be most in focus. (on my model, somewhere around 300+ feet) The balance of the picture (from the 20 ft up to infinity that you gave as an example) may be in acceptable focus only if the aperture is set to f/32 (on my model). If you have it set on a more open aperture, say f/5.6 with focus set to infinity, the area of acceptable focus may only be between 100-300 ft, not 20-300 ft.
If you "google" the phraes "download leica manual" you can sometimes find a pdf link with illustrations that can better explain with images what I'm talking about, and how to use the depth of field of a lens, the aperture and the rangefinder patch to more precisely focus.
__________________
Take care of the luxuries and the necessities will take care of themselves. --Dorothy Parker
joewehry is offline   Reply With Quote
Old 05/01/08, 12:41 AM   #6 (permalink)
Erfahrener Benutzer
My 1954 9cm F4 Elmar has the button on the side, it is the collapsible lens. To me used properly, the lens has to be extended and the button pressed to focus.
If that sounds like what you have, post back. If it's still confusing (it was to me!), I can post some pictures.
brianv is offline   Reply With Quote
Old 05/01/08, 11:56 AM   #7 (permalink)
Erfahrener Benutzer
Right... I forgot there is ONE 90 with a unlocking button...
Old 05/02/08, 06:33 PM   #8 (permalink)
Neuer Benutzer
Thanks for all the helpful replies. I'll try to be more helpful by disclosing greater detail about my lovely lens. It's an Ernst Leitz, Elmar 90mm collapsable lens, f=9cm, 1:4. It is equipped with the silver locking button on the side. I have an M6. I just got this camera and I was using a 50mm lens happily, thoughtlessly matching up images in the range finder and producing some very pleasing pictures. But with the 90 mm, I don't see the two images so I am a little baffled, not to mention a bit intimidated. Any advice is appreciated.
Marisa
Old 05/02/08, 07:11 PM   #9 (permalink)
Erfahrener Benutzer
OK, you have the only 90mm lens which is a little complicated to manage... is a collapsible lens, and you must EXTRACT it to be able to focus; to be precise, extract and turn it to secure the lens "tube", and you must do this with the lens at infinity (button "locked"). When the lens is correctly extracted, you can push the button and freely focus it as usual. The lens extracted is like this :
The same applies when you want to collapse the lens : must be set at infinity, button "clickes", ok to turn & collapse the tube.
Old 05/02/08, 07:49 PM   #10 (permalink)
Erfahrener Benutzer
fotografr's Avatar
Nice looking lens you have there, Luigi.
fotografr is offline   Reply With Quote
Old 05/02/08, 10:05 PM   #11 (permalink)
Neuer Benutzer
dear Luigi,
that is a nice lens. it looks just like mine. OK, after a little twisting the tube so the F-stop numbers face up, it worked. Oh so nice to feel it smoothly focus. Thank you so much. I can't wait to try it out.
Marisa
Old 05/02/08, 11:42 PM   #12 (permalink)
Erfahrener Benutzer
Marisa - you'll love the output from that lens. I used one to photograph my family throughout the 1980-90's and still marvel at the results.
Old 05/03/08, 11:15 AM   #13 (permalink)
Erfahrener Benutzer
Quote:
Yea, pity it isn't collapsible on M8... but my best Elmar 90 on M8 is the three elements version: absolutely fantastic, and also the one with the most precise focusing.
And, Marisa.. don't abandon this forum after having solved your little problem: there are too few women here: post some pics soon !!!
Old 05/03/08, 07:14 PM   #14 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by luigi bertolotti View Post
[...] but my best Elmar 90 on M8 is the three elements version: absolutely fantastic, and also the one with the most precise focusing.
Luigi:
I have heard good things about this lens, and am looking for one. How common/rare are they. Distinguishing features? Approximate price range? Any help you can provide will be appreciated.
Grazie.
Guy
gvaliquette is offline   Reply With Quote
Old 05/03/08, 08:00 PM   #15 (permalink)
Erfahrener Benutzer
Guy, the 3 elements is the best of Elmars 90, definitely (keep this for sure,, they are a specific passion for me... I have 7 all different ). For me, better also than the Elmar C for CL : it's compact, light, robust, good for macro (lenshead is removable for Visoflex use) : the BM version (which I have) isn't so rare... at the moment, a quick look at Schouten and Beimeister reveals 3 for sale ranging 400 to 750 Euros (this last, imho, is a sort of top price for a very fine item), the SM version (which I haven't) is much rarer but, for me , the 3 elem. is above all a usable little tele for film Ms and M8... the SM is a piece for collecting (Schouten has also for sale a super rare 3 elements with a strange, pre-series mount... stellar price)
Has a std. E39 filter size, so no problem with UVIR, and also the lens hood (IUFOO/12575) is easy to find.
Old 05/06/08, 01:20 AM   #16 (permalink)
Erfahrener Benutzer
I've been favoring the collapsible Elmar lately. The rendition of the lens with color film is wonderful. It preserves shadow detail and refuses to blow highlights. It gave me a series of wonderful portraits in full sunlight. And- collapsed it fits into my M3's ever-ready case with the top cover closed. I was using it last month when a professional photographer, a Photo-editor for the town newspaper, walked over to admire it. Told me he'd much rather be using film over digital.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
