Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 04/11/08, 07:12 PM   #1 (permalink)
Benutzer
Default Developing Tri-X in D76
Anyone can tell his/her own developing tipe for Kodak Tri-X in D76? Just to cross-check with mine.
Kodak Tri - X 400 in 400 asa Developing time: 11:30
kodak Tri - X 400 pushed 800 asa Developing time : 13:00
I'm also trying to find a correct time for Kodak T- Max 400 pushed at 400 , 800, 1600,3200. Developed in D76 as well. If you know, I'm pleased to get the correct time.
Bye
Annibale
Annibale G. is offline   Reply With Quote
Old 04/11/08, 07:24 PM   #2 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Default Re: Developing Tri-X in D76
Annibale, I always start here for developing times...
The Massive Dev Chart: B/W Film Development Times, Processing Data
Gives you a starting point if nothing else.
__________________
Steve
Website - www.steveunsworth.co.uk
Picture a week - http://www.steveunsworth.co.uk/PAW_blog/?page_id=9
stunsworth is offline   Reply With Quote
Old 04/11/08, 08:18 PM   #3 (permalink)
Benutzer
Default AW: Developing Tri-X in D76
First, I used the standard times, you can find them inside the filmbox: D76 1:1, 9:45
But I was not satiesfied with the results and found an advice at the Kodak-homepage. Kodakt says: "You can develop one 135-3 roll (80 square inches) in 473 mL (16 ounces) or two rolls together in 946 mL (one quart) of diluted developer. If you process one 135-36 roll in a 237 mL (8-ounce) tank or two 135-36 rolls in a 473 mL (16-ounce) tank, increase the development time by 10 percent."
Now I develop the Tri-X like this: D76 1:1, 10:40. The results are much better. So, for the T-Max 400 I do it in the same way: 10 percent more... D76 1:1, 13:45
Good luck, Alex
AlexEs is offline   Reply With Quote
Old 04/11/08, 08:22 PM   #4 (permalink)
Benutzer
The links
http://www.kodak.com/global/en/profe...17.14.18&lc=en
KODAK PROFESSIONAL D-76 Developer: Tech Pub J-78
KODAK PROFESSIONAL TRI-X Films
Old 04/11/08, 09:31 PM   #5 (permalink)
Benutzer
Well I use mainly a couple of tank : one is 450ml and the other is 950ml.
Could I consider the 450ml the smaller one and the 950ml the bigger one?
Annibale
Old 04/13/08, 06:20 PM   #6 (permalink)
Benutzer
For both of your tanks I would use the standard times for D76 1:1, I mean 9:45, maybe 15-30 seconds more, so you have to try...
After a few rolls you will find your way, because a lot of things can influences the developing-process, for instance here in Berlin we have very hard water, so the watering takes much more time.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
