Leica User Forum B+H The Professional's Source - Leica
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 04/10/08, 01:45 AM   #1 (permalink)
Benutzer
cosmonaut's Avatar
Default Nokton 40mm frameline modification
Has anyone here modified there 40mm Nokton to bring up the 35mm framelines on an M6? I have a link to someone on Flickr that has done it and it seems simple enough. It not a big deal with it as is, but I find the 35mm framlines more accurate than the 50mm.
cosmonaut is offline   Reply With Quote
Old 04/10/08, 08:13 AM   #2 (permalink)
Erfahrener Benutzer
doubice's Avatar
Default Re: Nokton 40mm frameline modification
The lens’ bayonet lug, which activates the frame selector, has to be filed back a smidgeon. The 35mm lens setting is the ‘default’ setting of the frame selector system, where the selector does not move at all.
I did this by filing small sections of the lug at a time, until the frame selector did not activate the 50mm setting. Care has to be taken so that no filings end up in the helical mount or the lens’ internals……
FYI – the lug that activates the frame selector is the one at 9 o’clock, with the lens in horizontal orientation and the bayonet facing you. It is the on the other side of the lens lock detent.
Good luck,
Jan
doubice is offline   Reply With Quote
Old 04/10/08, 09:56 AM   #3 (permalink)
Erfahrener Benutzer
Default AW: Re: Nokton 40mm frameline modification
Here is a link with an illustrated description (en francais) of the modification:
summilux.net :: Voir le sujet - Modification Nokton 40mm 1,4
veraikon is offline   Reply With Quote
Old 04/10/08, 08:22 PM   #4 (permalink)
Benutzer
cosmonaut's Avatar
Default Re: AW: Re: Nokton 40mm frameline modification
Thanks for the advise. I may give it a go.
Old 04/10/08, 10:05 PM   #5 (permalink)
Erfahrener Benutzer
doubice's Avatar
Another hint - in the pictured modification, the lug was filed at an angle. I did mine by filing to shorten the lug; this is how all Leica mounts are set up. The longest lug is the one for the 28/90mm frame pair, 50mm is mid-length and 35mm the shortest.
Best,
Jan
Old 04/10/08, 10:14 PM   #6 (permalink)
Erfahrener Benutzer
findwolfhard's Avatar
Default AW: Nokton 40mm frameline modification
Hello!
You might use an engraver`s tool, like a "Dremel" or any other similar type of micro-high-speed-drill with a small tool bit.
#DREMEL ONLINE SHOP
you have better control,-
good luck Wolfhard
findwolfhard is offline   Reply With Quote
Old 04/11/08, 05:14 AM   #7 (permalink)
Erfahrener Benutzer
doubice's Avatar
Yes, a Dremel would be the tool of choice. Since we all need more than one hobby to stay sane in this world , I also dabble into model trains and have a few Dremel tools at the ready. It was a Dremel with a cut-off dic that I used.
Best,
Jan
Old 04/11/08, 08:31 AM   #8 (permalink)
Erfahrener Benutzer
bill's Avatar
Can I be the dissenting voice here?
Why do it?
35mm - Angle of view approx. 64 degrees
40mm - Angle of view approx. 57 degrees
50mm - Angle of view approx. 45 degrees
So a nominal 7 degrees difference between 40 and 35, and a nominal 8 degrees difference between 40 and 50.
Personally, I use this lens for street and occasional low light shots. I would rather have a bit more on the negative than a bit less. I shoot it as a "generous" 50mm as a result.
Regards,
Bill
__________________
Bill Palmer (Gentleman Amateur and Leica Lout)
________________________________
"God is not on the side of the big battalions, but on the side of those who shoot best."
12 of my best
Some of my images
bill is offline   Reply With Quote
Old 04/11/08, 10:05 AM   #9 (permalink)
Benutzer
I have ground off the frame selector of my Nokton 40 SC to bring up the 35mm frame on my M8 and to my eye, the 35 frame on the M8 approximates more closely the field of view of the 40mm than the 35mm that it is designed for. Just my view, of course.
howard_cummer is offline   Reply With Quote
Old 04/11/08, 05:27 PM   #10 (permalink)
Erfahrener Benutzer
doubice's Avatar
Quote:
Given the inaccuracy of the M8's frames, this is true. A 40mm lens is more at home with the M8's 35mm frame. I use a Canon RF 25mm lens, coded and on a 24/35mm adapter - surprisingly (or not.....), it just about matches the 24mm frame.
Best,
Jan
Old 04/11/08, 11:50 PM   #11 (permalink)
Erfahrener Benutzer
bill's Avatar
Howard, Jan, I understand that with the M8, but the OP referred to an M6. That's why I don't understand.
Regards,
Bill
__________________
12 of my best
Some of my images
Old 04/11/08, 11:55 PM   #12 (permalink)
Benutzer
cosmonaut's Avatar
It seems the 35mm framelines are more accurate and are about 100% fill. It's not a big problem to pull the lever over while shooting. I am sure in time I will get really comfortable with it. I just thoght if it was an easy DIY I would give it a go. Now. What's the worse that can happen if I fail?
Old 04/13/08, 07:13 PM   #13 (permalink)
Erfahrener Benutzer
Hello !
Worst case? Filings could be caught in focusing thread!
best regs Wolfhard
Old 04/13/08, 07:15 PM   #14 (permalink)
Erfahrener Benutzer
Bill
Hi Bill, from 57 to 64 ,- 7 difference, from 45 to 57 it seems to be closer to 12!
Just my humble opinion,
so theres some sense in it for me,
best regards Wolfhard
Old 04/13/08, 08:57 PM   #15 (permalink)
Erfahrener Benutzer
bill's Avatar
*stands in corner*
Well spotted Wolfhard!
Regards,
Bill
__________________
12 of my best
Some of my images
Old 04/13/08, 09:34 PM   #16 (permalink)
Erfahrener Benutzer
Default AW: Re: AW: Re: Nokton 40mm frameline modification
*stands in corner*
Regards,
Bill
Hi Bill, what would you expect from a bloody teacher?
Best regards
Wolf
Old 04/13/08, 10:05 PM   #17 (permalink)
Erfahrener Benutzer
bill's Avatar
Default Re: AW: Re: AW: Re: Nokton 40mm frameline modification
Best regards
Wolf
ROTFL!
But Sir...
I did my homework, see...?
Can I go out and play now?
Regards,
Bill
__________________
12 of my best
Some of my images
Old 04/14/08, 09:28 AM   #18 (permalink)
Erfahrener Benutzer
Bill,- you may for this time only! But make sure you are back home at five!
Wolfhard Gradgrind
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
