| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections |
#1 (permalink) |
Erfahrener Benutzer
Anyone can tell his/her own developing tipe for Kodak Tri-X in D76? Just to cross-check with mine.
Kodak Tri - X 400 in 400 asa Developing time: 11:30 kodak Tri - X 400 pushed 800 asa Developing time : 13:00 I'm also trying to find a correct time for Kodak T- Max 400 pushed at 400 , 800, 1600,3200. Developed in D76 as well. If you know, I'm pleased to get the correct time. Bye Annibale |
#2 (permalink) |
Erfahrener Benutzer
Annibale, I always start here for developing times...
The Massive Dev Chart: B/W Film Development Times, Processing Data Gives you a starting point if nothing else.
__________________
Steve Website - www.steveunsworth.co.uk Picture a week - http://www.steveunsworth.co.uk/PAW_blog/?page_id=9 |
#3 (permalink) |
Benutzer
First, I used the standard times, you can find them inside the filmbox: D76 1:1, 9:45
But I was not satiesfied with the results and found an advice at the Kodak-homepage. Kodakt says: "You can develop one 135-3 roll (80 square inches) in 473 mL (16 ounces) or two rolls together in 946 mL (one quart) of diluted developer. If you process one 135-36 roll in a 237 mL (8-ounce) tank or two 135-36 rolls in a 473 mL (16-ounce) tank, increase the development time by 10 percent." Now I develop the Tri-X like this: D76 1:1, 10:40. The results are much better. So, for the T-Max 400 I do it in the same way: 10 percent more... D76 1:1, 13:45 Good luck, Alex |
#5 (permalink) |
Erfahrener Benutzer
Well I use mainly a couple of tank : one is 450ml and the other is 950ml.
Could I consider the 450ml the smaller one and the 950ml the bigger one? Annibale Last edited by Annibale G. : 04/11/08 at 10:37 PM. |
#6 (permalink) |
Benutzer
For both of your tanks I would use the standard times for D76 1:1, I mean 9:45, maybe 15-30 seconds more, so you have to try...
After a few rolls you will find your way, because a lot of things can influences the developing-process, for instance here in Berlin we have very hard water, so the watering takes much more time. |
| Thread Tools | |
| Display Modes | |
