Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more spcialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old February 25th, 2008, 08:41 AM   #1 (permalink)
Erfahrener Benutzer
Default Oily aperture blades
Hi
Are there slight traces of oil on the aperture blades that can be seen in the following picture?
Or are these just normal signs of use?
Best regards
R2-D2 is offline   Reply With Quote
Old February 25th, 2008, 04:37 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: Oily aperture blades
If there are oil spots on the aperture blades (I can't tell from the image) it is less of an issue with an M lens than it is with an auto-diaphragm lens like an SLR lens. That said, it wouldn't be normal for a lens of that age and could be an indicator that a CLA is on order.
__________________
Ian Watts
www.ianwatts.net
wattsy is offline   Reply With Quote
Old February 25th, 2008, 04:50 PM   #3 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Do you have the lens in front of you? The shiny spots just looks like shiny spots from the metal blades moving against each other, not oil.
robsteve is offline   Reply With Quote
Old February 25th, 2008, 05:27 PM   #4 (permalink)
Benutzer
I've heard of this condition before, and have it on my 80's vintage 50mm Summicron. As I recall, the recommendation was to keep lenses at their maximum aperture when not in immediate use to minimize lubricant migration.
malcolm is offline   Reply With Quote
Old February 25th, 2008, 07:05 PM   #5 (permalink)
Erfahrener Benutzer
Default Re: Oily aperture blades?
Quote:
No, I got the picture from that infamous auction site.
This is probably most likely - a local repairman said the same thing. I was just curious, because I haven't seen this on newer lenses...
Old February 27th, 2008, 03:18 AM   #6 (permalink)
Erfahrener Benutzer
I have heard that what looks like oil on aperture blades is actually a result of the lens being exposed to excessive heat.
The lubricant used on aperture blades is not an oil but a dry lunricant and it changes state and looks like oil due to excessive heat exposure. Lenses with this condition need to be CLA'ed and re-lubricated.
This may be true or it may be hogwash - it's just what I have heard (I haven't called Leica to ask the service dept.)
Does anyone know if this is true or not?
__________________
"Compensating for lack of skill with technology is progress toward mediocrity. As technology advances, craftsmanship recedes... The one thing we've gained is spontaneity, which is useless without perception."
- David Vestal
darkstar2004 is offline   Reply With Quote
Old February 27th, 2008, 03:37 AM   #7 (permalink)
Neuer Benutzer
Quote:
Originally Posted by R2-D2 View Post
Hi
Best regards
Oh god, the lens is a complete write off, you going to have to either throw it away or donate it to me for "parts"...
Oil on blades on these lenses isnt a big deal like it is in SLR lenses just because setting the diaphragm is absolute. However, if you are in a hot climate that oil can over time evaporate and settle on the lens elements (which are cleanable), but make for a reasonably unusable lens.
If you can afford the time or money to have it cleaned then doing it would be wise.
__________________
..you know what to do & when to do it..
devtank is offline   Reply With Quote
Old February 27th, 2008, 08:24 AM   #8 (permalink)
Erfahrener Benutzer
Quote:
Just read the thread carefully before you start ranting... The lens is not in my possession.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
