Leica User Forum 5% Discount for Forum Members
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Register now
Tags:
Old 02/13/08, 12:39 AM   #1 (permalink)
Erfahrener Benutzer
Default Leica SL2
I have an R9 and love it, but I've read a little about the SL/SL2 and am intrigued about the viewfinder. I also have the chance to pick one up on the cheap. That being the case, can anyone provide some knowhow about the SL2 vis-a-vis the R9 and let me know if my 90 APO and 50 Lux will fit? Thanks in advance.
pcsmythe is offline   Reply With Quote
Old 02/13/08, 12:54 AM   #2 (permalink)
Benutzer
Default Re: Leica SL2
Hi,
I have a R8 and but recently bought a SL2. The vf is bigger and more bright but a little less contrasty. in dimm light it is better but in bright light it can be too much.
I had it cla'd and really like the smoothness of this camera. Feels like a M2.
If your lenses fill fit depends on the cams. The SL2 needs the two Sl cams. 3 cams lenses can be used, R-only cams lenses can be used but will have no coupling. Rom lenses can not be used but might be converted.
My 50 lux does fit. i also have a 50 which has only the r-cam. The 90 apo is very recent. Might not have the sl cams.
Cheers,
Michiel Fokkema
michiel_fokkema is offline   Reply With Quote
Old 02/13/08, 12:57 AM   #3 (permalink)
cwf
Erfahrener Benutzer
cwf's Avatar
You might find this explanation of the cams on R lenses helpful:
Leica FAQ - Why do R lenses come in 2/3-CAM or ROM mounts?
__________________
Craig
cwf is offline   Reply With Quote
Old 02/13/08, 04:11 AM   #4 (permalink)
Erfahrener Benutzer
Any conversion to 3-cam means ROM contacts will be removed. For lenses that have SL mirror clearance and ROM, another option is to use a slightly-modified SL (flange milled to accept R-only lenses) with a slightly modified lens (2nd cam added). This cannot be done with the SL2 because the camera's first cam follower (for the viewfinder aperture display) will foul the ROM contacts on the lens.
__________________
Doug Herr
Birdman of Sacramento
http://www.wildlightphoto.com
wildlightphoto is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
