| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections |
Leica Products
Leica M240 Amazon US | B&H | Dale | Adorama | eBay |
Leica M Monochrom B&H | Dale | Adorama | eBay |
Leica M-E Amazon US | B&H | Dale | Adorama | eBay |
Leica X Vario B&H | Adorama | Dale | Amazon | eBay |
Leica M9-P Amazon US | B&H | Dale | eBay |
#181 (permalink) |
Erfahrener Benutzer
Ad
I'm expecting an X1 type camera, called the X2, with interchangeable lenses and an EVF - either fixed or optional. M and R lenses to be used via an adaptor.They could be radical and fit a full frame sensor, but I expect it'll be a 1.3 crop. I also expect I'm probably going to be wrong <grin>. |
| Thank You says | Peter D Lux 2 (20/03/12) |
#182 (permalink) |
Erfahrener Benutzer
Perhaps Leica will suprise everybody and announce a dedicated high quality 35mm film scanner just so that those of us who are still stuck in the dark ages with film can continue to post photos on the web.
Oh look there goes a flying pig!
__________________
---------------------------------------- Howard |
#183 (permalink) | |
Erfahrener Benutzer
Quote:
Well if there is a possibility of a B&W only M10 I would certainly hold onto my M8, not only for IR work but colour images, as well as a back-up. Up until now I have considered my M8 as a downpayment on a M9 or a new M10, however I would love to keep it. This is sounding better all the time
#184 (permalink) |
Erfahrener Benutzer
How do you think Leica will decide what should be introduced ?
Consider that they are out of capacity in lens production ....and expect to be in this position until the new factory comes on line . The have two capacity constraints (1) specialty glass availability from Japan and (2) equipment to produce lens elements . The glass shortage is gradually clearing up but will take until the end of the year . The factory issue is based on deciding to buy new equipment for the new factory . Also consider that when you add capacity to a factory you need ..skilled technicians to train new technicians and to work in the new equipment and processes . Lens production capacity will drop in the months preceding and following the move . Dealers report that they now have access to M9P s and willing buyers but NO LENSES . Has anyone seen anything that would indicate that leica will be able to increase the production of lenses over the new 6-12 months ? If not then they would be wise to introduce products that use lenses not made in Solms . The other factor would of course be the availability of sensors or other critical body components . If so I would expect the M10 with incremental improvements . IMHO they should be driven by maximizing what they can produce . |
#185 (permalink) |
Erfahrener Benutzer
DSLR with matching slide/film copy attachment would probably beat on price any high quality dedicated film scanner especially brand new one coming from Leica.
__________________
Regards, Mladen |
#186 (permalink) | |
Erfahrener Benutzer
Quote:
Interesting thing is that even Zeiss & Voightlander are struggling to meet the demand for ZM/VM lenses.
__________________
Regards, Mladen |
#189 (permalink) |
Erfahrener Benutzer
Considering that is there is no month starting with an R this is as close as they can get for the R10 (digital full frame DSLR thingy, no autofocus of course). Also, all announcements have to be in spring when the camera buying population is still frisky. No-one needs an M10, but maybe I will get the M11 sometime if someone twists my arm sufficiently....
__________________
Stephen unofficial unmoderator ________________________________________________ my flickr site |
#192 (permalink) |
Neuer Benutzer
By the success of the M9, Leica management may want to entice the old Leicaflex crowd with a full frame digital camera. There are a lot of great R lenses out there, waiting to be used again.
#193 (permalink) | |
Erfahrener Benutzer
Quote:
![]() Nigel Tufnel: The numbers all go to eleven. Look, right across the board, eleven, eleven, eleven and... Marty DiBergi: Oh, I see. And most amps go up to ten? Nigel Tufnel: Exactly. Marty DiBergi: Does that mean it's louder? Is it any louder? Nigel Tufnel: Well, it's one louder, isn't it? It's not ten. You see, most blokes, you know, will be playing at ten. You're on ten here, all the way up, all the way up, all the way up, you're on ten on your guitar. Where can you go from there? Where? Marty DiBergi: I don't know. Nigel Tufnel: Nowhere. Exactly. What we do is, if we need that extra push over the cliff, you know what we do? Marty DiBergi: Put it up to eleven. Nigel Tufnel: Eleven. Exactly. One louder. Marty DiBergi: Why don't you just make ten louder and make ten be the top number and make that a little louder? Nigel Tufnel: [pause] These go to eleven. Last edited by Double Negative; 20/03/12 at 20:57. Reason: Fixed quote |
| Thank You says | steveclem (20/03/12) |
#195 (permalink) | |
Erfahrener Benutzer
Quote:
So I guess you could say the "R solution" isn't coming from Leica - but has been here in the form of other platforms. ![]() Besides, at this point does it really make any difference? R shooters have moved on. Leica isn't making any more lenses or bodies. What's in it for them? The milk has spilled. |
| Thank You says | marknorton (23/03/12) |
#196 (permalink) |
Sponsoring Member
I guess the answer to that raises a further technical question.
How hard is it to make one mirrorless digital camera take both M and R lenses? The M lens has its rear element very close to the sensor, whereas the R lens is a retrofocus lens, with a different mount. Presumably, the native Leica mirrorless would have an M mount, and Leica would then offer an adapter to take the exit pupil to sensor distance out to 47mm (the M mount has a shorter distance)? Cheers John
__________________
Modern Art = I could do that + yeah, but you didn't |
#197 (permalink) | |
Sponsoring Member
Quote:
90mm Elmarit-M on Ricoh GXR M Mount | Flickr - Photo Sharing! 28mm Leica Elmarit R on Ricoh GXR M Mount via Novoflex | Flickr - Photo Sharing! Regards, Bill
__________________
Bill Palmer Gentleman Amateur & Leica Ambassador emeritus Lightmancer ~ Rangefound Me on ipernity - images shown like they should be |
#198 (permalink) | |
Erfahrener Benutzer
Quote:
Leica had this R to M adapter (it's #22228/500934). And the Leica M cameras are actually mirrorless... Liveview is the simple answer |
| Thank You say... | IkarusJohn (21/03/12), steveclem (21/03/12) |
#199 (permalink) |
Erfahrener Benutzer
Wow, a Berlin party to announce Leica arrival in DC!
__________________
Pixels dancing to the rhythm of the moment. Ramchand Ramesh http://ramchandramesh.com |
#200 (permalink) |
Erfahrener Benutzer
The 3/19 Leica Newsletter, referring to the May 10th announcement, mentions '...for a "whole range of product launches".' and then goes on to note about the speculations, which include the M10, a mirrorless camera with EVF, an R lens "adequate solution", and the B&W-only M.
Paul |
| Bookmarks |
| Current eBay Ads |
Current bid:
360 USD (24 bids)
Current bid:
149.72 GBP (0 bids) |
| Thread Tools | |
| Display Modes | |
