Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags: , , ,
LinkBack (1) Thread Tools Display Modes
Old 07/23/06, 07:04 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Erfahrener Benutzer
kdemas's Avatar
Default Dry Cabinet- Controlled Environment
Does anyone here use a dry cabinet or other device to store their equipment when not in use? I have quite a bit of equipment that I am getting nervous about having in my home with no air conditioning (90+ degrees inside now).
If anyone knows of a quality dry cabinet or similar device I'd appreciate being pointed in the right direction.
Thanks!
Kent
__________________
_________________
The question is.... how many 50's can you own before you officially have a screw loose??
www.SendPhotos.com
www.Avanquest.com
kdemas is offline   Reply With Quote
Old 07/23/06, 10:57 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: Dry Cabinet- Controlled Environment
Kent,
In my opinion a controlled dry cabinet is not necessary, a cupboard with glass door so lenses are not stored in the dark and with some moisture absorbant is all that is required.
Here in australia we have a similar climate and I have only had fungus develop in lenses I have had in the tropics. Moisture absorbant sold here under name "Dampsorb" I think Calcium chloride, discarded when becomes wet, I prefer indicating Silica Gel, blue when active, turns pink when exhausted, reclaimed by roasting in oven until turns blue again, can be used many times over.
Regards, Stuart
stumac is offline   Reply With Quote
Old 07/23/06, 11:40 AM   #3 (permalink)
Erfahrener Benutzer
jlancasterd's Avatar
Hi Kent
You only really need a dry cabinet for storing cameras and lenses if the humidity is consistently high where you live and you have a lot of gear to store - high temperatures have little effect if the atmosphere is dry, although some glues may dry out (or melt) in really fierce conditions.
Cabinets are expensive, but a cheap alternative if you only have a small outfit is a hermetically sealed plastic box (eg Tupperware) and a bag of silica gel dehumidifier - which should be kept activated by periodic baking (at a low heat) to drive off absorbed moisture. I used this method for years on the coast in West Africa where temperatures reach 100 Fahrenheit, and humidity 90%, and had no problems.
John
Thanks!
Kent
__________________
John Dobson
jlancasterd is offline   Reply With Quote
Old 07/23/06, 11:50 AM   #4 (permalink)
Erfahrener Benutzer
stnami's Avatar
Lived on the equator for 3 years bought one never switched it on a waste of money. Anyway the computer would not fit especially if I was using it
__________________
sorta new exhibition 08.................................................. ... “doi knia” ETROUKO .............. junk omel
stnami is offline   Reply With Quote
Old 07/23/06, 12:11 PM   #5 (permalink)
Benutzer
Kent,
John is correct. You only need a dry cabinet if you live in high-humidity conditions.
If anyone needs a high quality dry cabinet Id suggest the Japanese brand Toyo-Living (www.toyoliving.co.jp). I understand their products are sold in USA under "Totech America" (Desiccators, Desiccant Dry Cabinets, Dry Box Storage - Totech America)
lloyd_chan is offline   Reply With Quote
Old 07/23/06, 02:36 PM   #6 (permalink)
Erfahrener Benutzer
uulrich's Avatar
Sun light (UV) prevents lenses from having fungus. John stated that silica gel can dehumid the lenses. I can confirm this. These silica gel bags can be re-used/reconditioned after a short drying process in an oven at around 120F - 140F.
__________________
Uli
Like good photography....? Just pop in at
http://www.leica-camera-user.com/cus...r-website.html
uulrich is offline   Reply With Quote
Old 07/23/06, 04:11 PM   #7 (permalink)
Erfahrener Benutzer
kdemas's Avatar
All,
Thanks for the excellent tips, I really appreciate it! I will be stocking up on some more dessicant and all should be well.
Have a good day!
Kent
__________________
_________________
www.SendPhotos.com
www.Avanquest.com
Old 07/24/06, 12:36 AM   #8 (permalink)
Benutzer
wilyum's Avatar
Lächeln Re: Dry Cabinet- Controlled Environment
Kent, I have several cameras and lenses which I protect with silica gel which I placed in a large picnic cooler (icebox) which has a gasket sealed lid which keeps out humidity. The box is insulated as well to guard against temperature spikes. It has lots of room, a removable shelf, and was very inexpensive! Best regards, Bill
wilyum is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/customer-forum/2054-dry-cabinet-controlled-environment.html
Posted By For Type Date
Dry Cabinet- Controlled Environment - Leica User Forum This thread Refback 05/13/07 04:01 AM
