Leica User Forum Robert White
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags: ,
LinkBack (1) Thread Tools Display Modes
Old 07/18/06, 03:40 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Neuer Benutzer
egpj's Avatar
Default Flash - 20 or 24D
What is the difference between these two Leica Flash units. I have them both and was under the assumption that the 24D would not work with the MP. I have used it on the MP several times though with good results. So what gives?
Glenn
egpj is offline   Reply With Quote
Old 07/18/06, 09:18 AM   #2 (permalink)
Erfahrener Benutzer
Default Re: Flash - 20 or 24D
from thread in old forum http://www.leica-camera.com/discus_e...tml?1130106723
--begin quote--
Carlos Morales (maneshake)
New member
Username: maneshake
Post Number: 3
Posted on Sunday, October 23, 2005 - 10:09 pm:
Hey Philip, I just bought the 24 and am still playing with it. The 24 is stronger. Also, Leica and Panasonic both recommend it as the best choice as a flash gun for the D2/LC1. I also recall that you can use the TTL/GNC on the 24, but not on the 20. Also, if you have the LC1 and the black 24...it looks sweet. It also comes with 2 diffusers. I pulled this of the Leica site for you:
Leica Camera AG of Solms is pleased to introduce the new LEICA SF 24D, an improved flash unit with automatic guide number control. The optimised functions offered by the LEICA SF 24D make it possible to control flash exposure directly through the camera, making this unit the perfect accessory for a wide range of Leica cameras. The LEICA SF 24D is suitable for use with Leica rangefinder and SLR cameras, and can also be connected to the LEICA CM analogue compact camera and the LEICA DIGILUX 2, which will be available from February 2004. The flash unit automatically recognises the type of camera to which it is connected, and adjusts itself to the relevant operating mode. Ease of use and compatibility with the full range of modern flash techniques are features of the LEICA SF 24D.
The LEICA SF 24D has retained all the application features of its predecessor model the LEICA SF 20, and has complemented these with new functions. For example, the range of automatic apertures has been enhanced. All apertures from 2.0 to 11 are available with this new dedicated flash unit. The LEICA SF 24D also provides improved flash compensation of +/- 3 EV.
The illumination angle of the LEICA SF 24D corresponds to a 35 mm focal length for the 35 mm system. The two ancillary screens supplied with the unit for the wide angle and telephoto range cover focal lengths of 24 mm and 85 mm respectively. The flash unit automatically recognises the two diffuser screens supplied, and immediately adjusts the range display to the new guide number.
--end quote--
I hope that helps.
--HC
ho_co is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/customer-forum/1752-flash-20-24d.html
Posted By For Type Date
Flash - 20 or 24D - Leica User Forum This thread Refback 05/14/07 07:58 AM
Similar Threads
Thread Thread Starter Forum Replies Last Post
M6TTL or M7TTL? clw Customer Forum 9 07/14/06 11:46 AM
CLUX 1 Exposure burkey Digital Forum 19 07/13/06 07:14 PM
D-LUX2 Settings Questions ECliffordSmith Digital Forum 5 07/06/06 10:59 AM
Pentax flash on Leica R8 bscott Customer Forum 0 07/05/06 02:41 PM
Mundial snapshots gverdon People 7 06/27/06 03:18 PM
