Leica User Forum B+H The Professional's Source - Leica
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more spcialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
LinkBack (1) Thread Tools Display Modes
Old January 16th, 2007, 11:00 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Erfahrener Benutzer
fernando_b's Avatar
Default R-body, time indication delay
Just some weeks ago I started to notice a problem in one of my R bodies. The exposure time indication in viewfinder (see image below), moves with delay with respect to the turning movement of the upper knob. This happens exactly when changing from 1/15 to 1/8. It doesn't happen in reverse direction. Does someone have experience of it?
Thanks,
Fernando.
fernando_b is offline   Reply With Quote
Old January 17th, 2007, 12:29 AM   #2 (permalink)
Erfahrener Benutzer
Frage AW: R-body, time indication delay
Fernando:
I just checked my R9: no unusual delay around 1/8, 1/12 and 1/15, or any other shutter settings for that matter.
Which R do you have?
Guy
gvaliquette is offline   Reply With Quote
Old January 17th, 2007, 12:38 AM   #3 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Default Re: R-body, time indication delay
It must be an R6 or 6.2. On the mechanical cameras, the shutter speeds displayed are linked to the shutter speed dial with a cord and I think the speed are on a ribbon. As the dial is moved the cord pulls the ribbon with the speeds on it past the window in the viewfinder. On the other end of the ribbon is a spring of sorts that takes up the tension. Something in the mechanism probably needs to be cleaned. When has the camera last had a Clean Lube Adjust (CLA)?
robsteve is offline   Reply With Quote
Old January 17th, 2007, 08:06 AM   #4 (permalink)
Erfahrener Benutzer
fernando_b's Avatar
Guy, it is an R6.
Robert, thanks for the explanation. If it is limited to the displayed speed, not affecting the actual shutter speed, then I have no problem.
I will test soon all shutter speeds.
Fernando.
Old January 17th, 2007, 10:14 AM   #5 (permalink)
Erfahrener Benutzer
SoFi-Chaser's Avatar
Default AW: Re: R-body, time indication delay
Quote:
Originally Posted by fernando_b
Guy, it is an R6.
Fernando.
Hi Fernando,
this morning, I tested my R8 and had no problem ("how can one loose the 1/12s?").
Sorry, forgot to check my R6x - it was before the first cup of coffee
I'm interested in this as well and I'll tell you.
However, you're "lucky" this happens with 1/15 and 1/8. With shorter shutter-speeds, it might be far more difficult to distinguish both speeds with your ears.
Regards
Torsten
__________________
... ebenfalls mit rotem Punkt überwiegend noch mit Film unterwegs ;-)
SoFi-Chaser is offline   Reply With Quote
Old January 18th, 2007, 08:08 AM   #6 (permalink)
Erfahrener Benutzer
fernando_b's Avatar
OK, it seems only a problem of the ribbon with speed values, not actual shutter speed. I've taken some shots of the same view with different aperture/speed couples and the negatives have all the same visual density. I will scan them and control the istograms but I'm already pretty sure the shutter is properly working.
Thanks all for the help,
Fernando.
Old January 19th, 2007, 01:11 AM   #7 (permalink)
Erfahrener Benutzer
Default AW: R-body, time indication delay
Fernando:
I just checked my R6.2 and it's fine, no delay. That body, which I bought new from KEH, has been performing absolutely flawlessly from day one!
Good luck.
Guy
Old January 20th, 2007, 12:42 AM   #8 (permalink)
Erfahrener Benutzer
Blinzeln AW: R-body, time indication delay
Quote:
Originally Posted by gvaliquette
Fernando:
Good luck.
Guy
Oops! ... bought USED from KEH ...
Sorry for that slip!
Guy
Old January 20th, 2007, 11:27 AM   #9 (permalink)
Erfahrener Benutzer
Fernando.
Hi Fernando,
I think that's it. Finally I could check it for myself. The R6.2 is fine, the far older R6, too. But there the indicated exposure times do not appear in the center of the rectangular field, but a little to the left. I believe that's simply a small misalignment. The shutter is OK.
Regards
Torsten
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/customer-forum/13781-r-body-time-indication-delay.html
Posted By For Type Date
R-body, time indication delay - Leica User Forum This thread Refback May 14th, 2007 07:55 AM
Similar Threads
Thread Thread Starter Forum Replies Last Post
First time out with my new M8 Iron Flatline People 10 January 9th, 2007 11:08 PM
Black-tape Leica M3 - Time magazine camera of the year?... nemeng Customer Forum 1 December 15th, 2006 01:02 AM
Gibt es eine Alternative zum Body Leica R 9 ! urleica Leica Kundenforum 31 August 17th, 2006 01:15 PM
Conversion of lens for digital M body Daniel kk Customer Forum 16 July 9th, 2006 08:06 AM
