| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more spcialised sections |
| Tags: filter |
#1 (permalink) |
Erfahrener Benutzer
A little while back, I got a s/h series 63 drop-in UV filter for my Hasselblad wide-angle lenses. These old "C" lenses take filters which drop into a recess in the front of the lens, and are then held in place by a threaded ring which screws into what you would think would be the filter thread. Anyhow, I was surprised to see that my nice new (old) filter was proudly engraved around the rim with the noble script "Leitz Wetzlar". How odd. Did Leica make filters for Hasselblad at one time? Or are there some Leica lenses which use these drop-in filters?
Best regards John Last edited by john_r_smith : January 12th, 2007 at 09:33 AM. |
#2 (permalink) |
Erfahrener Benutzer
Leica used the same kind of system, so I'm assuming that it just happens to be the same size as for one of the Leica R lenses.
I don't think Leica ever made filters for Hasselblad - indeed I don't think Leica actually make the filters either (they are made and branded for them). |
#3 (permalink) |
Erfahrener Benutzer
Aha
so there are some R-series lenses which use this system, are there? This might be a handy thing to know, as the Hasselblad filters are hard to find. PS James you are brilliant, your clue has helped me solve the mystery. The filter is a Leitz Series 8 UVa, and there is a whole range of Leica series 8 filters which will work just fine on the 'Blad wide-angles, including the early SWC. As these Hasselblad filters are getting scarce and expensive, this is good news. So what Leica lens are they intended for? John Last edited by john_r_smith : January 12th, 2007 at 11:11 AM. |
#5 (permalink) |
Erfahrener Benutzer
John,
Not brilliant, I just have a older style 35mm Summicron R which uses series filters (although I don't actually have any). The polariser would be good though because its held in place by the lens hood which has a little wheel that rotates the filter! The lens needs a CLA so when I get that done I'll treat it to the pola. I'm not sure which lenses use series 8 filters, I'm sure someone else will advise. |
#6 (permalink) |
Moderator
Are the "Series" series of filters still made?
__________________
Cheers, |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
The Minolta-derived f2.8 Elmarit-R 24mm uses series 8 filters, held in place by the lens hood - I used one for several years before buying the 21-35mm Vario-Elmarit.
__________________
John Dobson |
#8 (permalink) | |
Neuer Benutzer
Quote:
Stuart |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A Leica half-frame curiosity | TimF | Customer Forum | 7 | September 6th, 2006 07:41 PM |
