Leica User Forum 5% Discount for Forum Members
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Tags:
Old 01/12/07, 09:31 AM   #1 (permalink)
Erfahrener Benutzer
Default A Curiosity?
A little while back, I got a s/h series 63 drop-in UV filter for my Hasselblad wide-angle lenses. These old "C" lenses take filters which drop into a recess in the front of the lens, and are then held in place by a threaded ring which screws into what you would think would be the filter thread. Anyhow, I was surprised to see that my nice new (old) filter was proudly engraved around the rim with the noble script "Leitz Wetzlar". How odd. Did Leica make filters for Hasselblad at one time? Or are there some Leica lenses which use these drop-in filters?
Best regards
John
john_r_smith is offline   Reply With Quote
Old 01/12/07, 10:49 AM   #2 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
Default Re: A Curiosity?
Leica used the same kind of system, so I'm assuming that it just happens to be the same size as for one of the Leica R lenses.
I don't think Leica ever made filters for Hasselblad - indeed I don't think Leica actually make the filters either (they are made and branded for them).
__________________
Regards,
James
www.earleygallery.com
earleygallery is offline   Reply With Quote
Old 01/12/07, 10:57 AM   #3 (permalink)
Erfahrener Benutzer
Aha
so there are some R-series lenses which use this system, are there? This might be a handy thing to know, as the Hasselblad filters are hard to find.
PS James you are brilliant, your clue has helped me solve the mystery. The filter is a Leitz Series 8 UVa, and there is a whole range of Leica series 8 filters which will work just fine on the 'Blad wide-angles, including the early SWC. As these Hasselblad filters are getting scarce and expensive, this is good news. So what Leica lens are they intended for?
John
Old 01/12/07, 11:07 AM   #4 (permalink)
Erfahrener Benutzer
Hi John , only one of my R lenses has a filter draw its the Apo Telyt 280 f4. Too small to be of use for other lenses at the front.
Canfred is offline   Reply With Quote
Old 01/12/07, 11:43 AM   #5 (permalink)
Erfahrener Benutzer
John,
Not brilliant, I just have a older style 35mm Summicron R which uses series filters (although I don't actually have any). The polariser would be good though because its held in place by the lens hood which has a little wheel that rotates the filter! The lens needs a CLA so when I get that done I'll treat it to the pola.
I'm not sure which lenses use series 8 filters, I'm sure someone else will advise.
__________________
Regards,
James
Old 01/12/07, 11:45 AM   #6 (permalink)
Moderator
andybarton's Avatar
Are the "Series" series of filters still made?
__________________
Cheers,
Andy
___________________________
2008 Spring Collection now released
andybarton is offline   Reply With Quote
Old 01/12/07, 11:52 AM   #7 (permalink)
Erfahrener Benutzer
jlancasterd's Avatar
Quote:
They are still listed in the B+W catalogue.
The Minolta-derived f2.8 Elmarit-R 24mm uses series 8 filters, held in place by the lens hood - I used one for several years before buying the 21-35mm Vario-Elmarit.
__________________
John Dobson
jlancasterd is offline   Reply With Quote
Old 01/12/07, 04:56 PM   #8 (permalink)
Neuer Benutzer
Quote:
Originally Posted by john_r_smith
Aha
John
They also fit the old 180mm f2.8 elmarit-R (which I use them for), and possibly the old 250mm as well.
Stuart
sender is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
A Leica half-frame curiosity TimF Customer Forum 7 09/06/06 07:41 PM
