| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections |
LinkBack (1) | Thread Tools | Display Modes |
#1 (permalink)
Benutzer
I'm looking for a wide-angle lens for my R8 and R4.
Take a look at the condition of this lens, what are the white dots on the lens? Would it affect picture quality? Do you guys think it's worth US$650-? Please advise, thanks! ![]() |
#2 (permalink) |
Moderator
The spots could be dust, or cigarette ash or may be physical damage to the glass itself. It almost looks like a 30,000 mile car windscreen...
Judging by the damage to the hood (above the "LEITZ"), I would suspect the latter, but until or unless you can actually see the lens personally, it's very difficult to tell. If it's physical damage, then it will affect the image, in the same way, for example, that raindrops and dust on the front element do. I wouldn't buy a lens with front element damage like this, even at what looks like a good price. $650 is around £325, which is very, very cheap for a 16mm. However, you will always be wondering what the photographs would have looked like if the element hadn't been damaged. ffordes.com (in Scotland), have an E++ one for £599, so "your" one is almost certainly damaged.
__________________
Cheers, |
#3 (permalink) |
Benutzer
I just talked to the shop and they assure those are dust inside the lens, and would not affect image quality. I'll give it a shot and go from there, since its well under the market price.
Thank you for your opinion. |
#4 (permalink) |
Erfahrener Benutzer
Leo, Andy:
Even if these white spots are damage to the glass itself, the quality should not be impaired, beyond a probable unnoticeable loss of contrast. Given that this is most likely a lens that will be used little, for special effects shots, I would say: Save the $$$ and go for it. I had the Fisheye-Distagon 16mm f2.8 for the Contarex in a previous life. It was a lens I treasured and always carried on vacations and photo outings, but used only rarely. However, when the occasion presented itself, it was just fabulous. I still treasure a photograph of the Piazza del Pallio in Siena, taken from the top of the campanile with that lens! Guy |
#5 (permalink) |
Erfahrener Benutzer
while I am sceptical when it comes to used lenses, ask the seller if you can test the lens yourself... run a few roles and see how it works out... If they say no... forget it.
#6 (permalink) |
Erfahrener Benutzer
This lens looks fine, IMO.
The seller could clean the lens carefully for you and mail you an updated photo. These white spots will disappear most likely, perhaps a few might remain between the lenselements without harming the performance. Best |
#7 (permalink) |
Benutzer
I just bought the same type of lens from a german seller on eBay. And I remember seeing
the picture you gave and decided not to bid on it, for the reason that i wasn't sure whether it would show up in the photos. At the time, there were a handful of 16mm lenses on eBay. Each seller had a picture of the lens and the front, and so I went with the clearest one I saw. I look at it this way, if you're going to spend the money, get the best possible quality you can for what you're willing to pay. Also realize that if these spots do affect the image quality, repairing it will cost $$ or you will have to do some photoshop work. Balance that against the cost. You can check with the seller, but unless it's a retailer, I don't think they would accept returns on a used lens. It's always on an "as-is" basis. That being said, maybe the specks won't add up to anything at all. But perhaps for certain photos ( closeups, sky shots ) they may appear as small specs, but given the perspective it may or may not be noticeable. Either way, if you're not happy with the lens, you can sell it again on eBay. |
#8 (permalink) |
Erfahrener Benutzer
Leo, the lens will probably be ok. If you ever want to frighten yourself shine a torch through a lens, you'll be surprised how much dust there will be.
I don't believe you will ever see these spots on a photograph. If there is an issue it's likely to show itself as a slightly increased chance of flare - and even that's not by any means certain.
__________________
Steve Website - www.steveunsworth.co.uk Picture a week - http://www.steveunsworth.co.uk/PAW_blog/?page_id=9 |
#9 (permalink) | |
Erfahrener Benutzer
Quote:
I wouldn't buy that lens. It should be easy to get a better one for a good price. Cheers Greg |
#10 (permalink) |
Erfahrener Benutzer
Hi Greg, it won't be an issue. I've just checked with a DOF calculator and focussed at 3 feet and f16 the DOF is 1.12 feet to infinity. The dust spots will only be inches from the plane of focus.
__________________
#11 (permalink) |
Erfahrener Benutzer
Thanks, Steve. In Germany we say "Mach aus einer Mücke keinen Elefanten." ("Don't make a mountain out of a molehill.") Would mean here: "Don't make a mountain out of a dust spot." ;-)
Even so, I'd prefer a "clean" lens. Cheers, Greg |
#12 (permalink) | |
Erfahrener Benutzer
Quote:
I use my fisheye-elmarit very often, mostly at f8 to f16. Although the front lens is clear and clean in the morning, more and more dust can be found there, the later it is. On the slides I only see big spots of water on the front lens. Such small particles can hardly be seen, even on my all-sky-pictures of athmospheric phenomena. Replacing the front lens will be very, very expensive. If you only care about the results and if you'll use the lens not very often -- go for it! Regards Torsten
__________________
... ebenfalls mit rotem Punkt überwiegend noch mit Film unterwegs ;-) |
#17 (permalink) | |
Moderator
Quote:
Lots of R lenses are "Minolta" designs. And none the worse for that.
__________________
Cheers, |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/customer-forum/13474-leica-r2-8-16mm-fish-eye.html
| Posted By | For | Type | Date | |
| Leica R2.8 16mm Fish-eye Elmarit-R, need your opinion - Leica User Forum | This thread | Refback | 05/14/07 07:53 AM | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Leica credibility - what do you think? | cobbslane | Digital Forum | 94 | 03/06/07 12:08 AM |
| Official Leica Statements | sean_reid | Digital Forum | 359 | 03/05/07 11:12 AM |
| Leica, your name is M | sungnee | Customer Forum | 16 | 01/16/07 06:12 AM |
| Leica R2.8 16mm Fish-eye Elmarit-R, need your opinion | LVSBB6 | Digital Forum | 0 | 01/12/07 02:46 AM |
