Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 01/08/07, 12:07 PM   #1 (permalink)
Benutzer
Default How do do
How do you measure exposure with 24 and 21 mm lenses with M system?
Annibale G. is offline   Reply With Quote
Old 01/08/07, 12:23 PM   #2 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
Default Re: How do do
Same as you do with any other focal length. Use built in meter if its got one or a handheld/sunny 16 rule, and meter accordingly depending on the scene (beaches/snow allowing for compensation etc)
__________________
Regards,
James
www.earleygallery.com
earleygallery is offline   Reply With Quote
Old 01/08/07, 01:51 PM   #3 (permalink)
Erfahrener Benutzer
cbretteville's Avatar
Or use a handheld meter. I like using incident readings with the realy wide wide angle lenses rather than the internal meter.
- Carl
__________________
The M8 Metadata project
cbretteville is offline   Reply With Quote
Old 01/08/07, 06:23 PM   #4 (permalink)
Erfahrener Benutzer
If you photograph landscapes, and want the soil, woods, houses to be correctly exposed rather than the sky, then turn your camera sightly downward when taking the measurement.
christer is offline   Reply With Quote
Old 01/08/07, 06:40 PM   #5 (permalink)
Erfahrener Benutzer
wparsonsgisnet's Avatar
I would suggest 2 methods.
As Christer says, if you're outdoors, you can use pavement or grass as a substitute for a gray card reading. I have found, however, that the M8 meter correctly meters just about all the time, outdoors. It prefers to meter the sky, so if you want lower levels, either adjust manually, or meter your hand.
For shots where people are included, meter your hand or meter a face if you can get there.
I have shot about 1500 pix, now, with the M8, using 24, 35, 50, and 75mm lenses. The M8 meters correctly when not himdered. As an example where manual setting are required: I shoot stage productions, so I find the correct manual speed and aperture settings using the review screen.
__________________
Bill Parsons (wparsons@gis.net), Boston
wparsonsgisnet is offline   Reply With Quote
Old 01/09/07, 10:28 AM   #6 (permalink)
erl
Moderator
erl's Avatar
Annibale, it would help if you stated exactly what measuring equipment you have at your disposal.
Other posters will tell you what they do, but that is with their equipment. The point is what do you have, what do you shoot with your wide angles, etc. With that knowledge we can give you much more accurate advice, maybe,
Cheers,
Erl
erl is offline   Reply With Quote
Old 01/10/07, 03:50 PM   #7 (permalink)
Benutzer
Ok. My problem came because I've red somewhere that with lens below 28mm the exposure meter in M7 doesn't work. Maybe I was wrong. I hope so.
Annibale
Old 01/10/07, 05:07 PM   #8 (permalink)
Erfahrener Benutzer
I don't have an M7 so can't comment. I use an M4, M6 pre-ttl, and now the M8.
I tested my newly acquired 24mm lens on the M6 to make sure it was ok, while waiting for my M8 to arrive. The M6 metered correctly.
__________________
Old 01/10/07, 05:47 PM   #9 (permalink)
Benutzer
nyrich's Avatar
I've been using a Voigtlander 21mm LTM lens with an M adaptor that brings up the 35mm frame lines on my M6. The 35mm frame lines seem to work as a pretty good guide for the metering area covered with a 21mm lens.
__________________
Rich
nyrich is offline   Reply With Quote
Old 01/11/07, 10:37 PM   #10 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Annibale, I use the 15 Heliar on the M6 & MP and it works great
I used it on the M8 for testing and it works great too !
cheers
JC
jc_braconi is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do I SAVE files in C1???????? wparsonsgisnet Digital Forum 8 12/17/06 02:29 PM
How Do You Read RAW images from a D-Lux 2 & M8 Using an Apple MacBook Pro? rick123 Digital Forum 8 12/03/06 12:57 PM
How do I "register" my M8 scjohn Digital Forum 2 11/27/06 03:06 AM
How many times do I have to tell you.....? elansprint72 People 0 07/11/06 10:19 PM
How do I get a picture the right size for the forum? flatfour Digital Forum 2 07/07/06 06:58 PM
