| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections |
#4 (permalink) |
Erfahrener Benutzer
If you photograph landscapes, and want the soil, woods, houses to be correctly exposed rather than the sky, then turn your camera sightly downward when taking the measurement.
#5 (permalink) |
Erfahrener Benutzer
I would suggest 2 methods.
As Christer says, if you're outdoors, you can use pavement or grass as a substitute for a gray card reading. I have found, however, that the M8 meter correctly meters just about all the time, outdoors. It prefers to meter the sky, so if you want lower levels, either adjust manually, or meter your hand. For shots where people are included, meter your hand or meter a face if you can get there. I have shot about 1500 pix, now, with the M8, using 24, 35, 50, and 75mm lenses. The M8 meters correctly when not himdered. As an example where manual setting are required: I shoot stage productions, so I find the correct manual speed and aperture settings using the review screen.
__________________
Bill Parsons (wparsons@gis.net), Boston Last edited by wparsonsgisnet : 01/08/07 at 06:42 PM. |
#6 (permalink) |
Moderator
Annibale, it would help if you stated exactly what measuring equipment you have at your disposal.
Other posters will tell you what they do, but that is with their equipment. The point is what do you have, what do you shoot with your wide angles, etc. With that knowledge we can give you much more accurate advice, maybe, Cheers, Erl |
#8 (permalink) |
Erfahrener Benutzer
I don't have an M7 so can't comment. I use an M4, M6 pre-ttl, and now the M8.
I tested my newly acquired 24mm lens on the M6 to make sure it was ok, while waiting for my M8 to arrive. The M6 metered correctly.
__________________
Bill Parsons (wparsons@gis.net), Boston |
#9 (permalink) |
Benutzer
I've been using a Voigtlander 21mm LTM lens with an M adaptor that brings up the 35mm frame lines on my M6. The 35mm frame lines seem to work as a pretty good guide for the metering area covered with a 21mm lens.
__________________
Rich |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How do I SAVE files in C1???????? | wparsonsgisnet | Digital Forum | 8 | 12/17/06 02:29 PM |
| How Do You Read RAW images from a D-Lux 2 & M8 Using an Apple MacBook Pro? | rick123 | Digital Forum | 8 | 12/03/06 12:57 PM |
| How do I "register" my M8 | scjohn | Digital Forum | 2 | 11/27/06 03:06 AM |
| How many times do I have to tell you.....? | elansprint72 | People | 0 | 07/11/06 10:19 PM |
| How do I get a picture the right size for the forum? | flatfour | Digital Forum | 2 | 07/07/06 06:58 PM |
