Leica User Forum
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Register now
Old 12/19/06, 01:26 AM   #1 (permalink)
Benutzer
Default Pradovit projector questions
My Pradovit CA2500 arrived. It is in great condition as are the accessories. It seems like this unit didn't get much use. The packaging for the replacement bulb looks very 1970s.
The image is incredibly sharp and the unit operates smoothly. The illumination is also very even corner- to-corner. However, the projected image tends very warm (yellowing). Is this normal? If this related to the bulb used or the condensor needs cleaning? Can I do this myself?
I read about the bright light kit for the Pradovits some time ago. Maybe that can solve my problem?
Thanks.
cpclee is offline   Reply With Quote
Old 12/19/06, 08:32 AM   #2 (permalink)
Erfahrener Benutzer
Default AW: Pradovit projector questions
It might also be the projection screen you are using. Also, is the lamp on full or reduced power (there is a switch at the back of the projector). In the reduced power setting, the light tends to be more yellowish.
Andy
wizard is offline   Reply With Quote
Old 12/19/06, 07:46 PM   #3 (permalink)
Erfahrener Benutzer
doubice's Avatar
Default Re: Pradovit projector questions
Chris,
Best screen for Leica projection is one with a white matte surface. Also check the bulb for correct wattage. The CA2500 should come with with a 24V/250Watt bulb. Some owners changed these to a 24V/150Watt bulb. The only advantage of doing this was a reduced heat output.
Which lens came with your projector? Did you check if it is clear and without any haze? And - I appologize for this question in advance - are you projecting in a fully darkened room?
All the best,
Jan
doubice is offline   Reply With Quote
Old 12/20/06, 06:08 AM   #4 (permalink)
Benutzer
Thanks for all the replies.
I replaced the bulb with a new one and indeed the warm tint went away. The old bulb
showed a little bit of browning inthe glass--possibly from all these years of sitting there
not getting used--which was causing the tint. It seems like this projector was a demo unit.
It came with training booklets from Leica along with a test slide. The inside is completely
prestine with no dust whatsoever.
I'm floored by the image quality this projector delivers! It is so uniformly sharp and bright.
My wife and I went through several years worth of slides and now wonder why we didn't
buy one sooner.
I guess I will stick with film for a while longer!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pradovit 153 - Qualität und Leistung harald_ludwig Leica Kundenforum 8 10/09/06 12:23 AM
Pradovit Ersatzteile gauss Leica Kundenforum 1 10/07/06 01:52 PM
Ärger mit Pradovit P 600 tiefenschärfe Leica Kundenforum 4 09/11/06 07:04 PM
Diamagazine für Pradovit P 150 speter Leica Kundenforum 6 08/16/06 10:48 PM
Pradovit RT-s advice sought leicapages Customer Forum 9 07/21/06 02:47 AM
